How to determine the regulatory domain of an IAP105
  • 1.  How to determine the regulatory domain of an IAP105
    Posted Sep 07, 2012 08:05 PM
    I am looking at buying an IAP105 from eBay but the guy can't tell me what regulatory domain it is.
    In Canada I would need the IAP-ROW version is there someplace on the box or on the AP itself that he can look to see what version it is?
  • 2.  RE: How to determine the regulatory domain of an IAP105
    Posted Sep 07, 2012 08:56 PM
    The back of the access point has a Sticker and a Barcode that has IAP-105-XX
  • 3.  RE: How to determine the regulatory domain of an IAP105
    Posted Sep 08, 2012 12:59 PM
    Thanks cjoseph.
    Helpful as always! :smileyhappy:
  • 4.  RE: How to determine the regulatory domain of an IAP105
    Posted Sep 08, 2012 03:37 PM
    You can also find that info on the box......the MAC and Part# are listed.  IAP-105-US is the US version and IAP-105 (no designation) is the ROW version.
    One other place you can find this, if the AP is running, is in the WebUI under Maintenance > Configuration.
