How to disable 2.4Ghz on an INSTANT WLAN?
  • 1.  How to disable 2.4Ghz on an INSTANT WLAN?
    Posted Apr 30, 2016 01:35 PM
    I have a small Instant installation where all of the client devices are 5Ghz-capable and the spectrum is already polluted by many surrounding 2.4Ghz APs.
    Since I don't need the 2.4Ghz radios enabled for traffic and I prefer not to contribute to the pollution, how do I disable 2.4Ghz on all radios in an INSTANT network?
    Thanks!
    Ken Morley
  • 2.  RE: How to disable 2.4Ghz on an INSTANT WLAN?
    Posted Apr 30, 2016 01:38 PM
    You can either make your SSIDs 5G only or disable the radios
    >From the user guide:
    Band option:
    http://www.arubanetworks.com/techdocs/Instant_42_WebHelp/InstantWebHelp.htm#
    UG_files/WLAN_SSID_conf/ConfiguringWLANPro.htm%3FTocPath%3DWireless%2520Netw
    ork%2520Profiles|Configuring%2520Wireless%2520Network%2520Profiles|_____1
    UG_files/ARM/Configuring_Radio_Settings.htm%3FTocPath%3DAdaptive%2520Radio%2
    520Management|_____3
