How to disable AP225 eth1 port ?
  • 1.  How to disable AP225 eth1 port ?
    Posted Jul 07, 2018 06:04 PM
    Hello everyone,
    Is there a way to disable Eth1 port of the AP225 ?
    I tried to change the Ethernet Interface 1 port configuration to shutdown in the ap group configuration, but the interface remains up.
    Could you guys help me with this case?
    Regards
    Thiago
  • 2.  RE: How to disable AP225 eth1 port ?
    Posted Jul 08, 2018 03:08 AM
    The only real way to shut down an AP225 eth1 port is to not plug it in AFAIK.  Making a port "shut" in the configuration closes it off to user traffic, and not infrastructure functions like redundancy.
  • 3.  RE: How to disable AP225 eth1 port ?
    Posted Jul 08, 2018 04:25 AM
    Hi
    If it is a demand from the customer to have it connected maybe you can switch it off on the switch side?
  • 4.  RE: How to disable AP225 eth1 port ?
    Posted Jul 09, 2018 09:02 AM
    Thanks for the answers,
    I dont know why, but the customer want to have the 2 ports plugged , but dont want to configure a lacp or shutdown the the port on the switch side.
    I explained to him, if we disable it on the controller side, if the first port failure, the AP will be disconnected from the network and it will not work as a redundancy.
    My doubt is, configuring the shutdown profile in the interface ethernet1 for the ap group will disable this port ? Or this configuration just work for aps like 205h ?
  • 5.  RE: How to disable AP225 eth1 port ?
    Posted Jul 09, 2018 09:11 AM
    It will not disable the port for AP redundancy
  • 6.  RE: How to disable AP225 eth1 port ?
    Posted Jul 09, 2018 09:15 AM
