How to disable connect to Activate server
  • 1.  How to disable connect to Activate server
    Posted Apr 11, 2018 06:44 AM
    I saw many fail log about connect to Activate server and I have no demand to connect Activate. How to disable connecting to Activate server?
    Thanks.
  • 2.  RE: How to disable connect to Activate server
    Posted Apr 11, 2018 07:27 AM
    Is this a new or used access point?
  • 3.  RE: How to disable connect to Activate server
    Posted Apr 11, 2018 10:57 PM
    There are three AP online used and consist VC successfully.
    I see many try connected Activate log using command `show log system`. I try to search manual to find disable this, but no idea.
    Thanks.
  • 4.  RE: How to disable connect to Activate server
    Posted Jul 27, 2018 02:16 AM
    are there any news on this? I have some switches where i want to deactivate this to get a cleaner log.
  • 5.  RE: How to disable connect to Activate server
    Posted Jul 27, 2018 09:58 AM
    I recommend opening a new thread on this, as the resolution that applies to ArubaOS (including Instant) is likely to be different than the switch firmware.
