how to disable extended ssid in aruba IAP225
  • 1.  how to disable extended ssid in aruba IAP225
    Posted Jun 10, 2016 06:21 AM
     Hi guys,
    I'm trying to setup IAP Mesh, to do that i need to disable extended ssid configure.
    I did that, but when i reboot the IAP cluster, i notice that even i disabled extended ssid configure, but it still "enable" somehow. Could you please help me on this?
    IAP-Master# show swarm state
    AP Swarm State :swarm_config_sync_complete
    mesh ldart State :suspending
    Config in flash :yes
    factory SSID in flash :no
    extended-ssid configured :no
    extended-ssid active :yes
    Config load cnt :1
    VC Channel index :1
    IDS Client Gateway Detect :yes
    IAP-Master#
    !!!!!!! below is show running configure !!!!!!!!!
    IAP-Master# show running-config
    version 6.4.2.0-4.1.3
    virtual-controller-country SG
    virtual-controller-key 7cb3a37401c4b58e7d2658909293421bae74ec11eaa7104a76
    name VC
    virtual-controller-ip 16.178.233.63
    terminal-access
    ntp-server 192.168.1.10
    clock timezone Singapore 08 00
    rf-band all
    allow-new-aps
    allowed-ap 84:d4:7e:c6:1a:16
    allowed-ap 84:d4:7e:c6:1a:a2
    arm
    wide-bands all
    80mhz-support
    a-channels 36,40,44,48,36+,44+,36E
    min-tx-power 3
    max-tx-power 3
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin d47900ac330b2d8943a8064b472e7780
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule mest-p2p
    index 2
    wlan ssid-profile mest-p2p
    enable
    index 0
    type employee
    essid mest-p2p
    wpa-passphrase 363aafcf36ee54e0dac513467f1494a667f94b17e569a048
    opmode wpa2-psk-aes
    max-authentication-failures 0
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
  • 2.  RE: how to disable extended ssid in aruba IAP225
    Posted Jun 10, 2016 06:54 AM
    Hi!
    Try upgrading to the latest 4.2.3.2. Mesh on 802.11ac APs are supported from 4.2 and up.
    Cheers,
  • 3.  RE: how to disable extended ssid in aruba IAP225
    Posted Jun 10, 2016 07:17 AM
    Thank
    It works.
    extended-ssid active :no
    Config load cnt :1
    VC Channel index :1
    Config Init success cnt for heartbeat :0
    Config Init success cnt for register :0
    Config Init skipping cnt for heartbeat :0
    Config Init skipping cnt for register :0
    Config Init last success reason :N/A
    Config Init last success time :N/A
    IAP-Master# show version
    ArubaOS (MODEL: 225), Version 6.4.4.6-4.2.4.0
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2016, Aruba Networks, an HP company.
    Compiled on 2016-06-06 at 15:11:14 PDT (build 55341) by p4build
    FIPS Mode :disabled
    AP uptime is 2 minutes 47 seconds
    Reboot Time and Cause: AP rebooted Thu Jan 1 09:02:14 UTC 1970; Image Upgrade Successful
    IAP-Master#
