Howdy,
I was intrigued as I couldn't remember what the command were for EEE. It took some finding but I have an answer!
BTW - One of the manuals is called "Configurations Guide Index" and it was this one that told me that the EEE config was in section 5 of the LAN switching Manual otherwise I would never have found it.
The good news is that you don't need to do anything as the EEE feature is disabled on these switches by default.
If you wanted to enable it you would need to navigate to the interface context and issue:
GigabitEthernet 1/0/1 # port auto-power-down
Hope that answers the question
Ian
#Default#EEE#5130ei#comware
