How to disable the same SSID on multiple 7005 controller networks?
  • 1.  How to disable the same SSID on multiple 7005 controller networks?
    Posted May 18, 2022 05:59 PM
    I've got dozens of 7005 controllers, running 6.5, which have a particular SSID. I need these SSIDs to be disabled. Then I'll delete them in the future. The controllers all use a 7210 as a master.
    There's no way for me to do this on multiple controllers, I don't think. So is it a CLI I have to script, or a point-and-click exercise for each controller?
    Ambi
    Ambidexter
  • 2.  RE: How to disable the same SSID on multiple 7005 controller networks?
    Posted May 18, 2022 08:47 PM
    If they all have the same virtual AP, you should disable the virtual AP and the SSID will not appear.
  • 3.  RE: How to disable the same SSID on multiple 7005 controller networks?
    Posted May 19, 2022 12:34 PM
    I figured it out. Thanks
    -A
    Ambidexter
