How to disable the TLS 1.2 Cipher in Aruba ClearPass
This thread has been viewed 55 times
  • 1.  How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 08, 2023 03:55 AM
    Hi All,
    Is there anyway to disable below Ciphers in  the ClearPass.
    The ClearPass version :6.9.13
    | ssl-enum-ciphers:
    |   TLSv1.2:
    |     ciphers:
    |       TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (secp521r1) - A
    |       TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (secp521r1) - A
    |       TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (secp521r1) - A
    |       TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (secp521r1) - A
    |       TLS_RSA_WITH_AES_256_CBC_SHA256 (rsa 2048) - A
    |       TLS_RSA_WITH_AES_128_CBC_SHA256 (rsa 2048) - A
    |       TLS_RSA_WITH_AES_256_CBC_SHA (rsa 2048) - A
    |       TLS_RSA_WITH_AES_128_CBC_SHA (rsa 2048) - A
    |       TLS_RSA_WITH_AES_128_GCM_SHA256 (rsa 2048) - A
    |       TLS_RSA_WITH_AES_256_GCM_SHA384 (rsa 2048) - A
    |       TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (secp521r1) - A
    |       TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (secp521r1) - A
    Thank you.
    Sri
  • 2.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 08, 2023 08:50 AM
    Why would you want to disable TLS 1.2?
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.9.0/Content/SystemRequirements/EndOfSupport.htm
  • 3.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 08, 2023 08:11 PM
    Thank you for your reply, security team ask us to disable as these ciphers are not allowed in network.
    Sri
  • 4.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 08, 2023 10:04 PM
    Why? What’s wrong with them?
  • 5.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 08, 2023 10:11 PM
    That's our security requirements.
  • 6.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 09, 2023 02:58 AM
    Are you sure that you are not mixing up with SSLv2? That is considered insecure.
    TLSv1.2 is considered strong and its successor TLSv1.3 has still limited support, so disabling TLSv1.2 would probably break a lot of things. Expect WLAN Enterprise authentications (EAP) to fail as those depend on TLSv1.2 for secure operations.
    If you really want to disable TLSv1.2, then you would need to open an Aruba Innovation Zone request through your Aruba Partner as it's not possible to my knowledge.
  • 7.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 09, 2023 06:55 AM
    Why though?  TLS 1.2 isn't broken from an encryption standpoint?  That's like saying we don't want any Windows 11 computers, only Windows 10 and 7.  Maybe time for a new security team?
  • 8.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 19, 2023 08:56 PM
    Sri is not asking to remove TLS1.2 altogether rather to remove certain suites as they are being flagged - particularly RSA. I am running into this same thing now where vulnerability scans are flagging the ability to negotiate with TLS 1.2 cipher suites including RSA.
    Example:
    Out of all approved TLS 1.2 Ciphers - remove all RSA options. No where was it asked to remove TLS 1.2 entirely.
    List of Approved TLS 1.2 Ciphers
    • TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
    • TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
    • TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
    • TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
    • TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    • TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    • TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
    • TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
    • TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
    • TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
    • TLS_DHE_RSA_WITH_AES_128_CBC_SHA
    • TLS_DHE_RSA_WITH_AES_256_CBC_SHA
    • TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
    • TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
    • TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
    • TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
      Hope this clarifies and Sri's company can keep their security staff.
  • 9.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Nov 20, 2023 10:04 PM
    Edited by Sri Nov 20, 2023 10:08 PM
    Hi All,
    Finally I got update from TAC, saying that we cannot disable the ciphers because that feature is yet to be introduced in CPPM versions.
    Thank you all for your valuable suggestions and reply.
    Sri
  • 10.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Jan 09, 2025 05:31 AM
    Hi Sri,
    Greetings.
    Is it same on the version on the CPPM  6.11.9?
    Could you please help me with updates?
    Regards
    Aravind.
  • 11.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Jan 09, 2025 10:15 AM
    What do you want to do?
  • 12.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Jan 21, 2025 08:47 PM
    Hi Herman ,
    Thank you for the response.
    Insure tls deployment on the Nessus Scan
    We would like to know if the disable the weak cipher for the port 443, TLS 1.2.
    In which the CPPM version is 6.11.9
    Please help if this weak cipher can be removed.
  • 13.  RE: How to disable the TLS 1.2 Cipher in Aruba ClearPass
    Posted Jan 22, 2025 05:53 AM
    ClearPass does not support enabling/disabling individual ciphers as mentioned earlier.
    Your screenshot mentions 'High Strength Ciphers', so why would you consider those weak or would you like to disable them? All look pretty strong to me.
    Aruba performs active security testing on all of it's products, and if this would have been considered an actual issue, those ciphers would have been removed. It's well-known that security scanner tools have many false positives, detect things that may be theoretical correct, but in the actual implementation are not an issue. It may be the same in this case.
    I would recommend to open a TAC case, as I won't be able to provide further information.
    In case it helps, this is what I see on my ClearPass 6.12.4 (don't have access to other versions to test the same):
    PORT    STATE SERVICE
    443/tcp open  https
    | ssl-enum-ciphers:
    |   TLSv1.2:
    |     ciphers:
    |       TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (secp256r1) - A
    |       TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (secp256r1) - A
    |       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (secp256r1) - A
    |       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (secp256r1) - A
    |       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (secp256r1) - A
    |       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (secp256r1) - A
    |     compressors:
    |       NULL
    |     cipher preference: server
    |_  least strength: A
