Network Management
how to display all APs on my controller
  • 1.  how to display all APs on my controller
    Posted Sep 14, 2016 03:45 PM
    How can I display all my APs seen by my controller at once.  The command is >show ap database ( database-summary).  But this gives me just few at the time. i need them all so I can copy and paste it to a spreadsheet.
    Ray
  • 2.  RE: how to display all APs on my controller
    Posted Sep 14, 2016 03:52 PM
    show ap database long | redirect-output
    This will dump out a text file in the controller flash.
  • 3.  RE: how to display all APs on my controller
    Posted Sep 14, 2016 03:56 PM
    @DariusTheGreat wrote:
    Ray
    On the commandline, if you type "config t no paging" and then enter, it will give you output with no page breaks..
    EDIT:  Just "no paging" in enable mode should work.
  • 4.  RE: how to display all APs on my controller
    Posted Sep 14, 2016 06:12 PM
    Thanks so much.  It worked like a charm.
  • 5.  RE: how to display all APs on my controller
    Posted Apr 25, 2017 07:49 PM
    Thanks so much.  This work well
