How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
  • 1.  How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 02:02 PM
    I have implemneted wired 802.1x with cisco switchs and ongaurd agnet installed on all win 7 an win Xp clients the thing is that I want to do auto remediation for user so antivurus can instaled automatically how can I do that?
  • 2.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 02:08 PM
    In your posture policy, enable auto-remediation in the Antivirus configuration.
    Tim
  • 3.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 02:37 PM
    Make sure you check whats auto remediation action are supported based on the product you are using:
    https://<ClearPass IP>/agent/supportcharts/Win_AV_ProductConfig.xml
  • 4.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 03:59 PM
    So what exaclty does it do is it installl antivirus without client interaction?
  • 5.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 04:01 PM
    Auto-remediation only works if the client already has antivirus installed.
    It can turn it on, update it, etc but make sure you look at Vic's post for
    supported software.
  • 6.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 04:22 PM
    Actually alll we thought about is it will install the antivirus so ,now I need to reddirect useres who dont have antivirus to a FTP server to doenload it and show them a message with that so what is the steps to configure this and thanks in advance
  • 7.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 10, 2015 04:33 PM
    You can do something along the lines of checking for the antivirus status in your enforcement policy and if unhealthy, return a role to the controller that has a captive portal attached with the page to install it.
  • 8.  RE: How to do Auto Remediation for Antivirus in win 7 and WIN XP on Wired 802.1x service on cleapass?
    Posted Jun 11, 2015 02:07 AM
    so what I got is that I have to cretae enforcement profile with redirction to the FTP server for example?
    so what is the right syntax for the rulles in the Enforcment profile?
