How to do two step authentication, MAC-based & 802.1x?
  • 1.  How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 01:31 PM
    Hi guys,
    This is a great forum and I've benefited greatly from the knowledgeable posts here. I have a scenario where I need to authenticate devices based on MACs as well as their 802.1x credentials. How can I do that?
    I know that in the AAA profile for a particular VAP, I can set the user roles for MAC-authentication, user-derivation rules and 802.1x but how can I tie two of them together so that the user is not authenticated until he meets both of the following conditions:
    1) User's MAC address is in the user-derivation rules OR in the Internal DB (MAC Authentication)
    2) 802.1x authentication
    Any help is much appreciated!
    Cheers
  • 2.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 03:02 PM
    If you set both a 802.1x and MAC authentication profile, the client has to pass BOTH or the client will not be admitted to the network.  If you enable "L2 Authentication Fail Through" on the AAA profile, 802.1x authentication will continue if MAC auth is failed.  I hope this helps.
  • 3.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 05:36 PM
    Thanks for the quick reply cjoseph. I've applied both profiles now but I can't find the "L2 Authentication Fail Through" option that you mentioned. In the AAA profile, all I see are 6 options:
    Initial Role
    802.1X Authentication Default Role
    Wired to Wireless Roaming
    MAC Authentication Default Role
    User derivation rules
    SIP authentication role
    Where's this fail-through option?
  • 4.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 05:38 PM
    Do you have ArubaOS 6.x?  I forgot to tell you it only exists there.
  • 5.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 05:43 PM
    No I don't but I can get it though. Is 6.x stable though? Anything I should know about for the upgrade? It's a 4504 controller running 5.0.3.3 and a bunch of RAP-2WG APs.
  • 6.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 05:46 PM
    You don't have to upgrade just for that.  On your current version, it just won't let devices on if they don't pass mac address authentication as well was 802.1x authentication.
  • 7.  RE: How to do two step authentication, MAC-based & 802.1x?
    Posted Dec 17, 2011 05:48 PM
    Right, I understand. It would be nice to have that option as a check box though.
    Greatly appreciate your help!
