Network Management
How to edit my switches on airwaves
  • 1.  How to edit my switches on airwaves
    Posted Oct 09, 2019 08:49 AM
    Hello
    I am new to Aruba airwaves and would like to know how i can edit and configure my switches using the software.
    I have added some of the switches and can see there set up but just cant find where i can for example change the VLAN or enable/disable a port as we could using the old HP procurve.
  • 2.  RE: How to edit my switches on airwaves
    Posted Oct 09, 2019 09:41 AM
    This guide should give you an idea.
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00059667en_us&docLocale=en_US
