How to enable 802.11v - BSS Transition Management on controller ?
  • 1.  How to enable 802.11v - BSS Transition Management on controller ?
    Posted Aug 13, 2014 02:00 AM
    Model: Aruba 620
    Version: 6.3.1.9
    Does any aruba controller/instant AP supports 802.11k location measurement (LCI )?
  • 2.  RE: How to enable 802.11v - BSS Transition Management on controller ?
    Posted Aug 13, 2014 06:55 AM
    From the AOS 6.3 user guide, pg 385:
    To enable BSS transition management, you must advertise the 802.11k capability on the dot11k-profile that is
    associated to a Virtual-AP profile. For more details on enabling 802.11k profile, see Enabling 802.11k Support on
    page 377 .
    Interaction between 802.11k and 802.11v clients
    For 802.11k capable clients, the client management framework uses the actual beacon report generated by the client
    in response to a beacon report request sent by the AP. This beacon report replaces the virtual beacon report for that
    client.
    For 802.11v capable clients, the controller uses the 802.11v BSS Transition message to steer clients to the desired
    AP upon receiving a client steer trigger from the AP.
    802.11v is selectable in Instant OS 4.1, via Instant 4.1 User Guide, page 109
    Configuring a WLAN SSID for 802.11k Support
    You can enable 802.11k support on a WLAN SSID by using the Instant UI or CLI.
    In the Instant UI
    1. Navigate to the WLAN wizard (click Network>New or Network> Select the WLAN SSID>edit).
    2. Click the Security tab.
    3. Under Fast Roaming, Select the 802.11k checkbox.
    4. Click Next and then click Finish.
  • 3.  RE: How to enable 802.11v - BSS Transition Management on controller ?
    Posted Aug 13, 2014 07:04 AM
    Hi Howard,
    thx for your reply with details :smileyhappy:
    any idea on 11k location measurement ?
    -veeramacha
  • 4.  RE: How to enable 802.11v - BSS Transition Management on controller ?
    Posted Aug 13, 2014 07:12 AM
    Check out the AOS 6.4 user guide, that seems to be where more 802.11k support is documented.
