How to enable Bandwidth per client ?
  • 1.  How to enable Bandwidth per client ?
    Posted Nov 23, 2012 05:33 AM
  • 2.  RE: How to enable Bandwidth per client ?
    Posted Nov 23, 2012 06:20 AM
    Each user that authenticates ends up in a ROLE.  Roles are defined under Configuration> Security> Access Control.
    Edit the role that the user is in and Add a Bandwidth Contract for Up and/or Down depending on what you want to limit.
  • 3.  RE: How to enable Bandwidth per client ?
    Posted Nov 23, 2012 08:06 AM
    can you please provide the screenshots for configuring the same???
    Thank You
  • 4.  RE: How to enable Bandwidth per client ?
    Posted Nov 23, 2012 08:28 AM
    I do not have a screenshot.  Below is a copy of the instructions from the user guide.
  • 5.  RE: How to enable Bandwidth per client ?
    Posted Nov 23, 2012 08:34 AM
    Thank You
