How to enable client match? Best config tips?
  • 1.  How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:14 AM
    Hi Guys,
    I'm doing some POC of testing 6.3.0.0 , With two 135 units.
    Is there any config tips on how to enable clientmatch feature? What is the best configuration for it - please advise.
    Thanks.
    Me
    #AP135
  • 2.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:28 AM
    You need AOS 6.3.x.x
  • 3.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:33 AM
    You think so :)
    i know that - it was a mistype. (in the above post - i fixed it)
  • 4.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:34 AM
    vfabian - i have 620 with 6.3.0.0 with two,Is there any config tips on how to enable clientmatch feature? What is the best configuration for it - please advise. AP135 units...
  • 5.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:39 AM
    Pretty straight forward to config and the most important thing are the show commands that woud allow you see that Client Match is working
  • 6.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:42 AM
    10x
  • 7.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:43 AM
    Could also use the debugging to see in more detail what's going
    (controller) (config) #logging level debugging arm-user-debug <devicemac>
  • 8.  RE: How to enable client match? Best config tips?
    Posted Jul 12, 2013 03:34 AM
    and howto remove a client (false) marked "unsteerable" ?
    Thanks.
  • 9.  RE: How to enable client match? Best config tips?
    Posted Jul 12, 2013 01:10 PM
    Client Match        Enabled
    Client Match report interval (sec)                                  30
    Client Match Unsteerable Client Ageout (min)           2880          <--------- Edit this value to desired for age-out of unsteerable entries
    Client Match Sticky Client Check Interval (sec)           3
    Client Match Sticky client check SNR (dB)                   25
    Client Match SNR threshold(dB)                                   10
    Client Match Sticky Min Signal                                        70
    Client Match Restriction timeout (sec)                          20
    Client Match Load Balancing threshold (%)                20
    Client Match VBR Stale Entry Age (sec)                       120
    Client Match Max steer failures                                      5
    Client Match Load Balancing client threshold            10
    Client Match Load Balancing SNR threshold (dB)     30
  • 10.  RE: How to enable client match? Best config tips?
    Posted Jul 12, 2013 05:24 PM
    good tips
  • 11.  RE: How to enable client match? Best config tips?
    Posted Oct 01, 2013 01:53 PM
    Was this moved in 6.3.0.2?
  • 12.  RE: How to enable client match? Best config tips?
    Posted Dec 23, 2013 03:30 AM
    Where are those  numbers cannot find them in the GUI :(
  • 13.  RE: How to enable client match? Best config tips?
    Posted May 02, 2017 10:18 AM
    What are the commands you used to see this? what are some of the commands to edit these values?
  • 14.  RE: How to enable client match? Best config tips?
    Posted Jul 11, 2013 11:35 AM
    Anyone? :smileysurprised:
