How to enable different bandwidth on 5 and 6 Ghz (IAP615)
  • 1.  How to enable different bandwidth on 5 and 6 Ghz (IAP615)
    Posted 29 days ago
    I'm trying to enable 40Mhz on 5Ghz and 80Mhz on 6Ghz. I enabled the option 80Mhz in the RF settings and checked the checkbox of 6Ghz in the wide channel bands option.
    But on both radio's 5 and 6Ghz it's broadcasting 80Mhz (I disabled the 2.4Ghz radio). Whatever I do I'm not able to have 40Mhz on 5Ghz and 80Mhz on 6Ghz .
    Does anyone have experience with this?
  • 2.  RE: How to enable different bandwidth on 5 and 6 Ghz (IAP615)
    Posted 29 days ago
    Hi Dion,
    In the IAP WebUI, leave wide channel bands enabled for 5 and 6 GHz along with 80 MHz support enabled. Then edit the Valid 5 GHz channels and remove any ending with E (like 36E) and S (like 36S). E indicates 80 MHz and S indicates 160 MHz. Removing those channels from the Valid 5 GHz channel list will allow you to run 40 MHz in 5 GHz and 80 MHz in 6 GHz.
  • 3.  RE: How to enable different bandwidth on 5 and 6 Ghz (IAP615)
    Posted 28 days ago
    Hi Schmelzle,
    Thanks, I will test that.
