How to enable external USB port in aruba controller 7005
This thread has been viewed 28 times
  • 1.  How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 04:02 AM
    Anyone can teach how to enable external USB port in Aruba Controller 7005?
    As figure below, it disable the external USB port while controller is startup.
  • 2.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 11:23 AM
    What are you trying to use them for? The USB console port should work, but 4G uplink is not yet available.
  • 3.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 12:01 PM
    I just need to backup configure file and manual upgrade the firmware.
  • 4.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 12:03 PM
    Is the controller powered via AC power, 802.3af or 802.3at PoE?
  • 5.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 12:25 PM
    The controller was powered by 802.3af PoE.
  • 6.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 12:02 PM
    I was power up the controller via POE. Will controller auto disable USB if not enough power to controller?
  • 7.  RE: How to enable external USB port in aruba controller 7005
    Posted Jun 26, 2015 12:39 PM
    Yes on .af power the USB ports will be disabled.
  • 8.  RE: How to enable external USB port in aruba controller 7005
    Posted Jul 25, 2019 06:58 AM
    Reboot Reason: AP rebooted Thu Jul 25 15:46:37 IST 2019; Unable to set up IPSec tunnel, Error:RC_ERROR_IKEV2_TIMEOUT
