How to enable "terminal monitor" on a IAP
  • 1.  How to enable "terminal monitor" on a IAP
    Posted Jul 29, 2016 11:42 AM
    Is there a way to enable "terminal monitor" on a IAP so that logs get outputted to my SSH session?  I found there was a way to do this on a Switch - http://community.arubanetworks.com/t5/Campus-Switching-and-Routing/Aruba-Switch-debug-display-terminal-output/td-p/270255.  Is there a way to do it on an AP as well?
    show version
    ArubaOS (MODEL: 215), Version 6.4.4.4-4.2.3.1
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2016, Aruba Networks, an HP company.
    Compiled on 2016-04-15 at 04:54:34 PDT (build 54637) by p4build
    FIPS Mode :disabled
    AP uptime is 23 hours 27 minutes 23 seconds
    Reboot Time and Cause: AP rebooted Thu Jul 28 12:13:10 UTC 2016; Internet connection lost
