Network Management
How to enable TLS 1.2 service and disable SSL 3.0 in HP 1950 switch
  • 1.  How to enable TLS 1.2 service and disable SSL 3.0 in HP 1950 switch
    Posted Jun 22, 2022 12:27 AM
    I am facing an issue in HP switch which is having SSL 3.0 service and it showing in Vulnerability. And i want to allow the TLS service in same model but there is no feature of TLS service. Please help me here to identify the same, so that i can be able to disable the SSL service and can enable the TLS service.
    Yukesh
  • 2.  RE: How to enable TLS 1.2 service and disable SSL 3.0 in HP 1950 switch
    Posted 24 days ago
    You may have better luck on the Instant On community.
    Good practice would be to block access to the WebUI to only admin clients, and/or use out-of-band management to reduce the impact of such a vulnerability.
