In version 5.0.3.1 I am trying to delete a SSID but it errors out and says it is in use. It also seems not to be saving correctly. Thank you,Gabe
Is that SSID profile applied to an existing Virtual AP profile?
Run the following from the CLI if you don't get a reference shown in the WebUI. Some of the references don't always show (for example when used in traffic management profiles):
show references wlan ssid-profile <profile-name>
