Network Management
How to execute a command on Aruba Controllers via SNMP ?
  • 1.  How to execute a command on Aruba Controllers via SNMP ?
    Posted Jun 21, 2018 11:45 PM
    I am looking to execute a comman on the WLAN controller, the objective is to run a command like the one below. SNMP v2 or v3
    I am getting the MAC via 'wlsxTrapUserPhyAddress'
    for example execute the below command "aaa user delete mac xx:xx:xx:xx:xx:xx"
    Couldn't really find the MIB's or how to execute it ?
  • 2.  RE: How to execute a command on Aruba Controllers via SNMP ?
    Posted Jun 22, 2018 06:19 AM
    There is no SNMP write function in ArubaOS.  You can execute "aaa user delete via XML-API"  in ArubaOS 6.x https://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/XML_API/How_the__XML_API_Works.htm%3FTocPath%3DExternal%2520User%2520Management%7C_____2 or the rest api in ArubaOS 8.x and above.
  • 3.  RE: How to execute a command on Aruba Controllers via SNMP ?
    Posted Jun 29, 2018 03:28 AM
    XML works like a charm ... thank you
