How to: "Export" AP database to Excel
This thread has been viewed 32 times
  • 1.  How to: "Export" AP database to Excel
    Posted Sep 26, 2014 11:42 AM
    How to export an AP database to Excel.
    Log into the CLI of your controller. Issue the command “show ap database”. The output is:Show ap database.PNG
    Now copy the output
    Paste the output into a .txt document. Save the document.
    Open Excel, navigate to data > from text >and find the .txt file. This will start an import wizard. Sail through the wizard by accepting the default settings. Upon completion of the wizard you will need to place the data or just click “OK”
    You are finished.
    1.
  • 2.  RE: How to: "Export" AP database to Excel
    Posted Sep 26, 2014 11:50 AM
    You can also do:
    show ap database | redirect-output
    It is handy for large lists. It creates a text file of the output in the flash.
  • 3.  RE: How to: "Export" AP database to Excel
    Posted Nov 08, 2016 11:28 AM
    if you have airwave better grab a csv file from there.
