Hi , Would like to know if there are any options to factory reset a clearpass hardware unit.https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Reset-admin-password-for-ClearPass/ta-p/267386Am not able to login using appadmin, eTIPS123, the unit does not have any active support.
Do you have access to the UI?
If you have admin access to the WEBGUI you can reset the cluster password, if you loose both admin and appadmin you need help from TAC support to solve this.
See also https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-recover-password-on-Clearpass-policy-Manager/ta-p/275363
moving forward from 6.6, if TAC intervention is required, it will affect most partners as demo units typically do not have running support.
Noted but nevertheless.
