last person joined: 9 hours ago
How to find owner of an AP
  • 1.  How to find owner of an AP
    Posted Jul 13, 2017 06:31 AM
    I bought a AP on EBay.
    It seems the seller isn't the owner of the AP, because he can't erase it if Aruba central.
    If i connect the AP to the web, the AP kicked me out of the configuration site.
    Thank you you for helping me.
  • 2.  RE: How to find owner of an AP
    MVP EXPERT
    Posted Jul 13, 2017 06:46 AM
    There is no configuration on the AP which you can erase to remove it from Central. If you log a ticket with Aruba TAC they can verify the owner and remove from Aruba Central if required.
  • 3.  RE: How to find owner of an AP
    Posted Jul 13, 2017 06:53 AM
    Console into the AP, do a factory_reset  command, this will stop the AP looking for a particular address and delete all its settings.
    It will then broadcast the SSID 'instant', connect to this, open a web browswer and login with admin & admin.
    You can then configure the AP as you see fit.
    Good luck!
    Alexander.
