Network Management
How to find serial number of Airwave Server
  • 1.  How to find serial number of Airwave Server
    Posted Oct 08, 2012 03:42 PM
    Dear all
     How do i find the serial number for airwave  physical server , it is inside the rack and not visible from outside
     Can we retrive From GUI or from CLI
  • 2.  RE: How to find serial number of Airwave Server
    Posted Oct 08, 2012 04:31 PM
    If your AirWave is installed on a box purchased through Aruba Networks or a partner, then you should be able to get the service tag using this command:
    # dmidecode -s system-serial-number
    The output is a Dell service tag.
    http://www.airwave.com/support/knowledge-base/?sid=50140000000a9Nn
  • 3.  RE: How to find serial number of Airwave Server
    Posted Oct 08, 2012 04:46 PM
    Thank you verymuch  Rob
  • 4.  RE: How to find serial number of Airwave Server
    Posted Aug 20, 2015 01:07 PM
    I have an AMP running rel 7.6.2 that the dmidecode command does not work. Is there another way to find the serial number?
  • 5.  RE: How to find serial number of Airwave Server
    Posted Aug 24, 2015 01:56 PM
    @roday
    Can you expand more on how the dmidecode command didn't work?  Did it error out?  Did it have any console output return?  By default, dmidecode is not a default installed package, so you can check to verify if the dmidecode RPM package is installed:
    # rpm -qa dmidecode
    [root@robtest mercury]# rpm -qa dmidecode
    dmidecode-2.12-5.el6_5.x86_64
    If you find that this package is not installed, simply do a yum install (as long as your AMP can reach the internet, otherwise you may have to download the package and do the manual RPM install):
    # yum install dmidecode
    Once installed, try the command again and it should work as expected.
  • 6.  RE: How to find serial number of Airwave Server
    Posted Aug 24, 2015 04:30 PM
    Thank you very much. Great help!
