Hi there,
Regardless to the standards and regulatory domain, I want to force the EIRP of a 802.11a radio to be 28. How can I accomplish this?
Mo
You can set a value as high as 127, however the AP will limit the max EIRP to the highest supported power level supported by the regulatory body.
Anyway, to do what you are asking, disable ARM and then change the Tx EIRP in the 11a radio profile.
