when we generate user from Guest ProvisioningAruba can get report from user such as ,
time at login of usertime at logout of userbandwidth at user use
thank you
You're going to want to focus on the Client Session report. The best way is to have a specific SSID for guest users, and then to generate a Client Session report restricted by SSID.
Is it possible to generate a report on AMP listing every client that has connected to an SSID ? I have tried "Client Session : session data by SSID (list)" and this seems to produce a summary only - we would like a list of every client thta has used this SSID.
Mike
Closing the loop that this was reposted in a separate thread -> http://community.arubanetworks.com/t5/AirWave/Reporting-each-client-session-per-SSID/m-p/70986#M1727
