This brings me back to the original question: Does Aruba OS support RESTAPI for real and if so, what would be the correct configuration to confirm that?
Original Message:
Sent: Jun 13, 2024 03:04 PM
Subject: How to get REST API operational on Aruba OS 16.11 Switches (2530/2930)?
Like @herman say, try with
You can also check the web-management (show web-managment)
and also use local and not network_cli
ansible_connection: local
ansible_network_os: arubanetworks.aos_switch.arubaoss
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jun 11, 2024 05:32 PM
Tried 16.11.0018 and this is the error message I am getting:
FAILED! => {"body": "<HTML><HEAD><TITLE>307 Temporary Redirect</TITLE></HEAD><BODY bgcolor=\"white\"><CENTER><H1>307 Temporary Redirect</H1></CENTER></BODY></HTML>", "changed": false, "connection": "close", "content-length": "140", "content-type": "text/html", "location": "https://10.xx.xx.xx/rest/v6.0/login-sessions", "msg": "HTTP Error 307: Temporary Redirect", "status": 307, "url": "http://10.xx.xx.xx:80/rest/v6.0/login-sessions"}
How were your tests?
Does RESTAPI work on Aruba OS for real?
What are the correct configurations for it?
Original Message:
Sent: May 30, 2024 02:10 AM
can you try 16.11.0018 ?
i will try to check today with 2530 and RADIUS
Original Message:
Sent: May 29, 2024 03:43 PM
Tried on 16.11.0011 and 0015
Original Message:
Sent: May 29, 2024 03:09 PM
What minor release do you are using for 16.11 ?
Your configuration is already good, there is already this :
aaa authentication rest login radius server-group "SW-Radius" local
aaa authentication rest enable radius server-group "SW-Radius" local
Original Message:
Sent: May 29, 2024 11:08 AM
We are trying to make it RADIUS (or TACACS? - seen some threads that REST over RADIUS has troubles with Aruba OS)
What is the best practice for Aruba OS 16.11 (16.08+)?
Original Message:
Sent: May 27, 2024 09:38 AM
Ansible is a local user or remote (RADIUS ?)
Original Message:
Sent: May 27, 2024 09:35 AM
What I have tried to figure (please look at the original message), is why RESTapi does NOT process logins. Any logins (not just ansible)
- Http
Invalid user name/password on the REST session; the user 'ansible' is trying to login from the Switch WEB GUI
any user that can login to HTTP, cannot login to RESTAPI (the very same ansible user produces HTTP 400 bad request&failed authentication via ansible, but logs in to GUI)
so the question is what am I missing in the Aruba OS 16.11.xxxx switch config?
Original Message:
Sent: May 27, 2024 04:17 AM
Look good...
what do you have on /home/ansible/secret/credentials-ansible.yml ?
do you have try with curl ?
Original Message:
Sent: May 24, 2024 12:39 PM
Here is my playbook:
- hosts: all
gather_facts: false
collections:
- arubanetworks.aos_switch
vars:
- ansible_connection: network_cli
- ansible_network_os: arubanetworks.aos_switch.arubaoss
- ansible_command_timeout: 300
- ansible_httpapi_use_ssl: false
- ansible_httpapi_validate_certs: false
tasks:
- name: Include Credentials
include_vars:
file: /home/ansible/secret/credentials-ansible.yml
no_log: true
- name: Create VLAN 300
arubaoss_vlan:
vlan_id: 300
config: "create"
command: config_vlan
- name: Update vlan 300 with ipv4 address
arubaoss_vlan:
vlan_id: 300
config: "create"
command: config_vlan_ipaddress
vlan_ip_address: "10.20.30.40"
vlan_ip_mask: "255.255.255.0"
- name: Delete vlan 300 ipv4 address
arubaoss_vlan:
vlan_id: 300
config: "delete"
- name: update vlan 300 with dhcp helper address
arubaoss_vlan:
vlan_id: 300
config: "create"
command: config_vlan_dhcpHelperAddress
helper_addresses: "10.10.10.100"
Original Message:
Sent: 5/24/2024 7:53:00 AM
Subject: RE: How to get REST API operational on Aruba OS 16.11 Switches (2530/2930)?
What your playbook configuration ?
If you try with curl (or PowerArubaSW ;-)), it is working ?
for curl example you can look : https://networkingsupport.hpe.com/downloads/documents/RmlsZTo5OTBmZmUwZS03YjE3LTExZWQtYTcwNS1jMzc4NjBkYWVhMDY%3D
Original Message:
Sent: May 23, 2024 05:41 PM
Trying to enable REST api for ANSIBLE logins by following 16.11 OS Guide, but having no success whatsoever:
FAILED! => {"body": "{\"message\":\"Authentication failed.\"}", "changed": false, "connection": "close", "content-type": "application/json", "msg": "HTTP Error 400: Bad Request", "requestid": "", "server": "eHTTP v2.0", "status": 400, "transfer-encoding": "chunked", "url": "http://xx.xx.xx.xx:80/rest/v6.0/login-sessions"}
or
Http
aaa server-group radius "SW-Radius" host xx.xx.xx.xx
aaa accounting exec start-stop radius
aaa accounting system stop-only radius
rest-interface is enabled for HTTP/80
What is the right configuration for Aruba OS 16.11 and up?
