last person joined: 11 hours ago
How to get traffic on controller ?
  • 1.  How to get traffic on controller ?
    Posted Aug 17, 2017 12:05 AM
    Hi,all
          I use the following command to calculate flow rate:
    echo -n `snmpwalk -v2c -c public 192.168.0.10 IF-MIB::ifHCOutOctets.1 | cut -d' ' -f4` > /tmp/result.tmp
    echo -n `snmpwalk -v2c -c public 192.168.0.10 IF-MIB::ifHCInOctets.1 | cut -d' ' -f4` > /tmp/result1.tmp
    echo -n " " >> /tmp/result.tmp
    echo -n " " >> /tmp/result1.tmp
    sleep 10
    echo `snmpwalk -v2c -c public 192.168.0.10 IF-MIB::ifHCOutOctets.1 | cut -d' ' -f4` >> /tmp/result.tmp
    awk '{printf "Cernet egress rate: %d mbps
    ",($2-$1)*8/10000000}' /tmp/result.tmp echo `snmpwalk -v2c -c public 192.168.0.10 IF-MIB::ifHCInOctets.1 | cut -d' ' -f4` >> /tmp/result1.tmp awk '{printf "Cernet ingress rate: %d mbps",($2-$1)*8/10000000}' /tmp/result1.tmp
    But, I got the similar value,  can somebody tell me what's wrong?
  • 2.  RE: How to get traffic on controller ?
    Posted Aug 17, 2017 04:11 AM
    Not so sure what you mean by 'got the similar value'.
    I tried your script in a modified form (I removed the divide by 10M to get to bits per 10 seconds) and that produces something like this:
    Cernet egress rate: 7102224 bps
    Cernet ingress rate: 6233293 bps
    Cernet egress rate: 9516807 bps
    Cernet ingress rate: 8491288 bps
    Cernet egress rate: 7189673 bps
    Cernet ingress rate: 6194052 bps
    If you want to know why the ingress and egress are similar in magnitude, that may be because traffic is tunneled. Most of the client traffic that comes in on the interface via the AP tunnel, will go out almost instantaneous as decrypted client traffic. So unless you have the client VLANs on a different physical interface than the APs, you will see this pretty symmetrical traffic pattern.
    You will see similar on the controller itself:
    (md-7005-01) #show interface counters
    Port          InOctets     InUcastPkts     InMcastPkts     InBcastPkts
    GE0/0/0     56111156670       331810222        46136913          258436
    Port         OutOctets    OutUcastPkts    OutMcastPkts    OutBcastPkts
    GE0/0/0     43991147096       302752988        43813062           13238
    Will this be an answer to your question??
