Network Management
How to get UCC Data from the MM into Airwave
  • 1.  How to get UCC Data from the MM into Airwave
    Posted Mar 26, 2020 12:14 PM
    @micneesen wrote:
    Cluster 1 is assigned to one Airwave instance, cluster 2 and 3 to another. Keep in mind to include the MM in all Airwave and to ignore the controllers that should not be visible if you need UCC information.
    Hi, can you explain this point a bit further? I just noticed this because our Airwave UCC data has been broken since install and Aruba TAC has not been able to fix it. We are getting no UCC data in Airwave even though it is available in the MM dashboard. Is there some caveat you are aware of for UCC data to work properly from MM to Airwave?
    [This post has been moved and a new post created because it is unrelated to the current thread]
  • 2.  RE: How to get UCC Data from the MM into Airwave
    Posted Mar 26, 2020 12:21 PM
    What version of Airwave and what version of AOS on the cluster?
  • 3.  RE: How to get UCC Data from the MM into Airwave
    Posted Mar 26, 2020 01:37 PM
    Can you share TAC ticket number,will check details.
  • 4.  RE: How to get UCC Data from the MM into Airwave
    Posted Mar 30, 2020 02:10 AM
    Yes, sure.
    So we are using ArubaOS 8.5.0.1 in combination with AirWave 8.2.10.1.
    We needed to enable the UCC tranmission in the Controller Profile -> Management Config -> Default-amp or whatever profile you are using.
    Furthermore you need to activate the UCC collection on AirWave in the AirWave Setup -> General -> Additional AirWave Services.
    Be aware that this will only work (in MM setup) when MM is connected to AirWave. The UCC engine is only working on MM and therefore those information can only be obtained using the Mobility Master.
    Hope this helps.
