Network Management
[How-To] Getting Clarity Live up and running in 5 minutes!
  • 1.  [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Apr 08, 2016 08:03 PM
    Here's a quick How-To on setting up Clarity Live!
    PREREQUISITES
    • AirWave 8.2.x
    • AOS 6.4.3+
    CONTROLLER SETUP
    Clarity may already be enabled on the controller side. Let's take a look.
    First, let's verify that the controller is already sending AMON data to AirWave.
    • From the CLI, type:
      show mgmt-servers
      If you've set up AMON in the past, you should see your server listed as type "AirWave".
      (controller) #show mgmt-servers
      List of Management Servers
      Type     Primary Server  Profile
      AirWave  1.2.3.4    default-amp
      If your AirWave server is not listed, add it by running the command:
      mgmt-server type amp primary-server <airwave-ip> profile default-amp
    Now that we know AMON is configured, let's take a look at the AirWave profile and ensure that we're sending Clarity data.
    In the last step, you saw a Profile attached to the AirWave server. By default we have "default-amp", but you may have created your own.
    • At the CLI, run:
      show mgmt-server profile <profile-name>
      //example:
      show mgmt-server profile default-amp
      You should see something similar to this:
      Mgmt Config profile "default-amp" (Predefined (editable))
      Parameter          Value
      Stats              Enabled
      Tag                Enabled
      Sessions           Enabled
      Monitored Info     Disabled
      Misc               Enabled
      Location           Enabled
      UCC Monitoring     Disabled
      AirGroup Info      Disabled
      Inline DHCP stats  Enabled
      Inline AP stats    Enabled
      Inline Auth stats  Enabled
      Inline DNS stats   Enabled
      If the parameters beginning with "Inline" are not enabled, start by entering the mgmt-profile config mode:
      Next, enable the Inline stats options using the commands below:
      no inline-ap-stats-disable
      no inline-auth-disable
      no inline-dhcp-disable
      no inline-dns-disable
      That's it! Be sure to save your config.
    AIRWAVE
    Clarity Live is enabled by default, but we can verify by going to AMP Setup > General > Additional AMP Services > Enable Clarity Data Collection. This should be set to Yes.
    After a few minutes, you should begin seeing Clarity Live data!
  • 2.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Apr 15, 2016 12:42 PM
    Any suggestions on what to check when Clarity still isn't showing data when the settings are configured as above?
  • 3.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Apr 15, 2016 12:55 PM
    Enable AMON Data Collection:
  • 4.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Apr 20, 2016 05:14 PM
    Any ideas on why I would see these results when enabling the DHCP & DNS monitoring?
    (SEN-A650) (Mgmt Config profile "default-amp") #no inline-dhcp-disable
    DHCP monitoring configuration not supported on this platform
    (SEN-A650) (Mgmt Config profile "default-amp") #no inline-dns-disable
    DNS monitoring configuration not supported on this platform
    I am running 6.4.3.7 on a 650 controller.
  • 5.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Apr 22, 2016 09:01 AM
    Spoke to engineering. The 6xx controllers unfortunately cannot support Clarity Live due to memory requirements.
  • 6.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted May 12, 2016 06:59 PM
    Does the clarity collect and display live data OR it polls at certain intervals?
  • 7.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted May 12, 2016 09:37 PM
    The controller "pushes" the clarity data to Airwave using Amon.
  • 8.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Jun 09, 2016 06:57 AM
    We have Clarity running, and it looks good with 1 exception:
    It shows the resultes from various DNS servers, but not the 2 actually being used! Clients get DNS addresses through DHCP.
    Any idea why this happens?
  • 9.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Jan 27, 2017 01:07 PM
    Clients can statically assign the DNS server even when they receive their address via DHCP.
  • 10.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 17, 2017 10:04 PM
    Good day All,
    Any information on how it works in Hyper-V?.. Just installed using .ISO image of CE, however, it doesn't appear to be functional. My AMP server just doesn't see it even if all the settings in CE are applied and it can ping AMP.
  • 11.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 18, 2017 08:08 AM
    Hi Egor,
    Are you talking about AOS code 8.0.x, if YES then we have support for this code in our latest Airwave release but related to clairty support it says from 6.5.x and later.
    Since AOS 8.0.x code is new and in supported device list it is not mentioned clearily whether this code supports clarity data in Airwave or not.
    Enable clarity settings in AMP Setup > General>Additional AMP services page aswell.
    If all the setting enabled on AOS server side but still we are not seeing clairty data in Airwave then to confirm above (clarity support is there or not) we have to enable AMON debug logs in Airwave to see whether clarity data been sent to Airwave server or not?
    Please open TAC ticket.
    Pavan
    If my code address your query, give kudos:)
  • 12.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 19, 2017 03:25 AM
    Thank you.
    Clarity is enabled in Additional AMP Services. I can see its CPU/Memory consumption under APs/Devices. Its status is IDLE.
    Airwave is 8.2.3.1.
    Instant is 6.5.0.0-4.3.0.0_56428 (IAP-205). The highest I can see on HPE My Networking portal.
    According to this thread:
    https://community.arubanetworks.com/t5/Network-Management/no-data-collected-by-clarity/td-p/266404
    I need a higher version of Instant.
    At this point I've got nothing in Clarity Dashboard:
  • 13.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 19, 2017 10:01 AM
    Egor,
    I thought you are talking about controller code. Yes, clarity supported in IAP from 6.5.1.0-4.3.1.2 and this code is supported in AMP 8.2.3.1 latest version.
    I would recommend to upgrade the IAP code and also Airwave if it in older code and check the status.
    Pavan
  • 14.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 20, 2017 05:31 AM
    Updated to 6.5.1:
    However, everything is pretty the same:
    Also AppRF stopped working after the upgrade - no data there as well...
  • 15.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 20, 2017 05:58 AM
    We have support for clarity in mentioned code, have you upgraded the Airwave code to latest aswell?
  • 16.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 20, 2017 07:48 AM
    Please create a new thread. This thread is about Clarity Live.
  • 17.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 20, 2017 08:22 AM
    Hey!
    I´m running Airwave 8.2.3.1 and ArubaOS 6.5.1.4 at a customer and I have enabled Clarity data collection on Airwave side and AMON + all the inline stats on the controller side. I can see all the stats showing up in Airwave except DNS, anything specific that needs to be done for the DNS stats to work?
    Cheers,
  • 18.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 20, 2017 11:30 AM
    Hi christoffer,
    Make sure DNS stats also enabled, have you configured APs in split tunnel mode?
    When RAP configured in split tunnel mode, Any DNS query performed by client will not hit controller. Hence, the information will not be passed to Airwave server.
    I would recommand to open new TAC ticket to debug this issue, to see whether DNS data been sent from contorller to Airwave or not?
    Pavan
  • 19.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 21, 2017 05:50 AM
    Hi!
    The DNS stats are definately enabled to be sent from the controller. We have almost all VAPs in tunnel mode but no DNS stats are showing.
    I will consider opening a TAC case at a later time.
    Cheers,
  • 20.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Mar 28, 2017 04:54 AM
    Hi guys,
    Finally, it works:
    Had a chance to play with a newer IAP set up from scratch running the latest code - it appears something had been misconfigured in the original setup. Added back my original IAP-205 with wiped config - no problems so far.
    IAP firmware:
    Let's see how it goes. Thanks for your help. Cheers.
  • 21.  RE: [How-To] Getting Clarity Live up and running in 5 minutes!
    Posted Jun 26, 2017 09:36 AM
    Hi Chris,
    Were you able to fix your issue?
    You have to enable DNS lookups on your controller for DNS to be seen in Clarify on Airwave.
    I believe it is 'ip domain lookup' on the controller.
