Hard to tell based on just the screenshot. It probably will help to work with your partner or Aruba Support to interactively troubleshoot. And where I would start in this case is with the browser developer tools as there may be a request not working, and based on what request may be going where it may be possible to find out the issue. Without troubleshooting it's like shooting blind.
Original Message:
Sent: Aug 12, 2023 02:01 AM
Subject: How to hide ClearPass Login Label on Web Logins
Hi Herman,
Thanks for the suggestion. It did work.
But I have similar problem with login message.. default login message pops out and cannot delete..
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/828164a366c340c186010a7a8969c435.png)
How can I get rid of this
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c719554b1c53437c9a52edf0f337aa5e.png)
Akshatha
Original Message:
Sent: Aug 03, 2023 03:17 AM
Have you checked this response to remove the text through CSS?
Original Message:
Sent: Aug 03, 2023 01:36 AM
Hello, we are testing to create new web logins for Guest network. I have created new web page for testing. We have all the HTMLs defined in Header HTML. But the title and Login Lable appears on the top left of the Web Login Page when I try launching.
If I leave the title page blank, title goes away but 'Login' Lable still remains. How do I get rid of this Login Lable?
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/b8563b3df3794d13afd3fb2041c08f16.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/6aff7c71611b4df78039448e202089c0.png)
