Hello
I'm looking to upgrade my 2 x 48 port 3Com Switch 4400 stack. This stack currently has a 1Gb (multi mode) fibre uplink to another 3Com 4400 stack in my building approx 100m away.
3Com 4400 current hw config:
3Com Switch 4400 x 2 48 Ports in stack
3C17221 1000Base-SX module
Media Type: 1000 BASE-SX
CurrentPortMode: 1000 FD
Propsed replacement:
Product name: 2 x HP E2910-48G al Switch - Product number: J9147A
- Most importantly would the HP stack be compatible with the 3Com stack via the 1000 Base-SX fibre link? Or would I possibly get negotiation issues?
What part No's do I need to buy for:
- Part no: Cable used for linking the 2 HP switches together in a stack.
- Part no: Fibre transeiver module to work with multi mode fibre using 1000 Base-SX
- Although not important, is it likely that I could use 10Gb fibre uplinks links here on my multimode fibre, if so whats the part no and cost of those transeiver modules.
