Developer
How to I config Aruba with Strongswan for VPN connection?
  • 1.  How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 12, 2018 05:26 AM
    Dear my friend,
    I have 100 Aruba 303 devices. I want to configure VPN to manage devices through internet. I am using strongswan malware as vpn server. I have encountered connection problem of AP and strongswan. It is after a period of time, on the strong server, not checking the connection session of the AP to the server vpn. However, when you type 'show vpn status' on the AP, the connection status of vpn is still up. Is there any problem with AP 303, or my strongswan configuration has problems?
    Help me please!
  • 2.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 12, 2018 06:21 AM
    You‘re trying VPN through VPN?
  • 3.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 12, 2018 07:22 PM
    I have a CentOS 7 server. Strongswan is installed on the server with authentication method ipsecs ikev1. After installation I connected to the AP over the IP VPN. But then the connection was lost. On the AP, I checked with the command 'show vpn status'. And it said VPN is still UP.
  • 4.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 13, 2018 12:16 AM
    Instant APs only support VPN to a Aruba Controller. Or is there a new feature?
  • 5.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 13, 2018 03:00 AM
    I use this command:
    vpn ikepsk
    vpn primary
    vpn backup
  • 6.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 14, 2018 04:04 AM
    This is not possible. VPN is only allowed to Aruba Controllers.
    btw: you're not getting many responses because you posted in the wrong forum.
  • 7.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Nov 16, 2018 01:32 AM
    But, which forum should I ask?
  • 8.  RE: How to I config Aruba with Strongswan for VPN connection?
    Posted Mar 25, 2019 02:50 AM
    Hello Viet, I didn't try to make them work yet, but judging from the data sheet for the VIA client, it should be pretty straight forward and without any show stoppers. Ask the mailing list, if you have any concrete problems. Regards Noel Kuntze
