How to identify IAP 92 - that has been converted - on a controler ?
  • 1.  How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 08, 2015 08:40 AM
    Actualluy the question is in the subject, How to identify IAP 92 - that has been converted previously - on a controler ?
    Thanks in advance
    Best regards
    Thierry
  • 2.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 08, 2015 08:44 AM
    When it boots up, does it search for a controller or come up in Instant?
    (you can console in)
  • 3.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 08, 2015 09:07 AM
    I have IAP(converted)  an AP  attached to the controler and running. I do not have easy access to AP and IAP to check on console
    What I'm looking for, is a way to differenciate AP an IAP on the controler while they are already running....
  • 4.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 08, 2015 09:27 AM
    Is the AP a CAP or RAP connecting to the controller?
    An IAP working as a CAP will still create an IPSEC tunnel to the controller. Technically making it a sort of local RAP.
    Type: show crypto ipsec sa
    Grab the Inner IP and cross reference that IP by doing a show ap database long.
    I believe you will then be able to find out which one is the IAP.
  • 5.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 09, 2015 09:18 AM
    Any luck??
  • 6.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 11, 2015 02:38 AM
    ThierryD
    you can use show ap image version. Assuming you didn't do take to the apboot to do the IAP to CAP conversion, and just used the webUI method, then the AP will still have the instant load in it's second bank.
    Example below - this is hard to see due to the rediculous width of the output, but you can see one AP below 192.168.1.8 has an instant image in the backup image bank (6.3.1.4-4.0.0.5) , but the other AP shows two ArubaOS versions hence is unlikely to be a converted IAP (see note below)
    (sg-7030) #show ap image version
    Access Points Image Version
    AP           Running Image Version String                                                  Flash (Production) Image Version String                                       Flash (Provisioning/Backup) Image Version String                    Matches  Num Matches  Num Mismatches  Bad Checksums  Bad Provisioning Checksums  Image Load Status
    192.168.1.8  6.4.2.3(p4build@minorca.arubanetworks.com)#47524 Sat Dec 6 08:48:39 PST 2014  6.4.2.3(p4build@minorca.arubanetworks.com)#47524 Sat Dec 6 08:48:39 PST 2014  6.3.1.4-4.0.0.5(p4build@stan)#43022 Thu Apr 3 13:10:02 PDT 2014     Yes      1            0               0              0                           Done
    192.168.1.6  6.4.2.3(p4build@minorca.arubanetworks.com)#47524 Sat Dec 6 09:02:09 PST 2014  6.4.2.3(p4build@minorca.arubanetworks.com)#47524 Sat Dec 6 09:02:09 PST 2014  6.4.1.0(p4build@cartman)#43850 Tue May 20 23:07:58 PDT 2014         Yes      1            0               0              0                           Done
    Note:
    It is possible to totally remove the iAP image from the 2nd s/w bank on a converted iAP->CAP, but this can only be done from the apboot and by someone who 100% intended to make the AP unable to be recovered to iAP by pressing the reset button. If there is no chance that happened in your customer, then you can trust the above method.
    regards
    -jeff
  • 7.  RE: How to identify IAP 92 - that has been converted - on a controler ?
    Posted Jan 12, 2015 03:13 PM
    Thanks Jeff.
