Network Management
How to increase Airwave disk space?
This thread has been viewed 64 times
  • 1.  How to increase Airwave disk space?
    Posted Nov 20, 2017 12:40 PM
    Hello, I'm constantly running out of disk space on our Airwave server, I've changed some of the log retention and its helped a bit but not enough. What's the best way to add storage to the VM? Is this guide still relevant?
    http://community.arubanetworks.com/t5/Network-Management/Tutorial-Increase-diskspace-on-Airwave-running-on-VMware-Jan14/td-p/130739
  • 2.  RE: How to increase Airwave disk space?
    Posted Nov 20, 2017 09:31 PM
    Hi Chadd,
    You can follow the below KB for increasing disk size on Airwave,
    http://community.arubanetworks.com/t5/Monitoring-Management-Location/Resizing-CentOS-LVM-inside-VM/ta-p/174334
    Note: If you are on 8.2.4 or above you would have to involve TAC for performing the metioned steps.
  • 3.  RE: How to increase Airwave disk space?
    Posted Nov 21, 2017 10:50 AM
    Thanks, problem solved :o)
  • 4.  RE: How to increase Airwave disk space?
    Posted Dec 06, 2019 08:52 AM
    Do you know of a process to increase the disk size for AW after CLI access restrictions?  I am running 8.2.10 and my AW shows a 82 GB drive from a 400 GB VM allocation, and I need to increase that to the full amount.
  • 5.  RE: How to increase Airwave disk space?
    Posted Dec 06, 2019 09:01 AM
    Since CLI access is restricted you need to take help of TAC to increase LVMs, open TAC ticket.
