How to increase the DHCP Pool???
  • 1.  How to increase the DHCP Pool???
    Posted Dec 05, 2019 04:21 AM
    Greetings All,
     We have Aruba controller 7210 V 6.4.4.6 and we need to know how to increase the DHCP pool instead of 252 IP's to  512 IP's.
    I have uploaded the photos  for the current configuration
  • 2.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 04:35 AM
    I believe 7010 can scale upto 1000 leases pre 8.2 releases and 2048 post 8.2.
    In your case, looks like you have configured the subnet to be /24, which will give you 256 IP addresses. Change it to /23 and you will get 512 IP Addresses.
  • 3.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 04:58 AM
    thanks,
  • 4.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 05:41 AM
    Try updating the scope from CLI. I had funky isuses with GUI in the past. Do a show run and look for DHCP pool section. Copy the DHCP pool config, edit with the new subnet, remove the scope and re-apply.Works like a charm.
  • 5.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 05:50 AM
    Attachment(s)
  • 6.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 06:04 AM
    Should be something like:
    interface vlan 11
    no ip address
    ip address 192.168.1.2 255.255.254.0
    operstate up
    exit
    #Not the best DHCP pool names.
    no ip dhcp pool AP's
    ip dhcp pool AP_VLAN11
    default-router 192.168.1.2
    network 192.168.1.0 255.255.254.0
    dns-server 10.10.50.1
    authoritative
    If you have any other core switch/device that is advertising VLAN 11 subnet, you have to update the subnet to /23.
    Also noticed your VLAN 8 is /20:
    interface vlan 8
    ip address 172.8.1.2 255.255.240.0
    Make sure this is by design. You won't ne able to create a DHCP scope for /20 on an Aruba controller. Try using a dedicated DHCP server for this subnet.
  • 7.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 06:14 AM
    Hi Aziz,
    about your noticed for VLAN8 its already working for an end user
    interface VLAN 8
    Make sure this is by design. You won't be able to create a DHCP scope for /20 on an Aruba controller. Try using a dedicated DHCP server for this subnet.
    also as understand that the Aruba  controller 7210 can generate DHCP pool up to 5120
  • 8.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 06:17 AM
    My bad.. I thought you are using 7010.
  • 9.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 06:41 AM
    I received the below during the configuration
    (NESMA) (config-subif)#no ip address
    Error: Switch IP address is configured with this interface
  • 10.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 07:00 AM
    Also I tried to remove the vlan11 but i received the following
    (NESMA) (config) #no interface vlan 11
    ERROR: Cannot Delete Vlan Routing Interface:Remove IP Address before deleting the interface
  • 11.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 03:14 PM
    If you want to remove the L3 interface then 1st need to remove the IP from the interface and then remove the interface vlan 11.
    Try :
    int vlan 11
    no ip add
    no int vlan 11
    Raja
  • 12.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 05:43 PM
    Hi Raja,
    Is there a discussion on how to increase the DHCP pool?? Or are we discussing how to remove an L3 VLAN from controller?
  • 13.  RE: How to increase the DHCP Pool???
    Posted Dec 05, 2019 07:11 PM
    Hi Sri,
    Initially discussion starts for extension for DHCP , looks finally they
    removing on L3 interface....
    pls ignore if i am wrong.
    Thanks&Regards,
    Rajasekhar R
    07204921201
