Wired Intelligent Edge
last person joined: 10 hours ago
HOW to isolete ports on comware7
  • 1.  HOW to isolete ports on comware7
    Posted Oct 01, 2016 09:28 AM
    Hello Community!!
    I need isolete traffic of diferents ports, for example I have vlan 30 with a lot of servers (physical servers and virtual servers) and they must not communicate between them.
    I tryed with port isoleted but it doesnt work:
    sys
    port-isolate group 1
    interface range gig1/0/2 to gig 1/0/24
     port-isolate enable group 1
    I tryed with private vlan, but its a really long configuration!!
    do you have any idea to share:)
    best regard...
  • 2.  RE: HOW to isolete ports on comware7
    Posted Oct 02, 2016 04:27 PM
    Are all of the servers on the same switch?
  • 3.  RE: HOW to isolete ports on comware7
    Posted Oct 02, 2016 04:28 PM
    Then port isolate should work
  • 4.  RE: HOW to isolete ports on comware7
    Posted Oct 03, 2016 08:26 AM
    Hello mrzero,
    Is a mix, some servers are in the same IRF stack and others in second IRF stack.
    The fact is that isoleted-port doesnt work!! the servers can ping between them :(
  • 5.  RE: HOW to isolete ports on comware7
    Posted Oct 04, 2016 10:15 AM
    port isolation only works on the same switch, if you need this across multiple switches then isolated private-vlans is the answer to your request.
