last person joined: 11 hours ago
How to know controller is having bottleneck
  • 1.  How to know controller is having bottleneck
    Posted Sep 22, 2016 09:59 PM
    Is there any command in controller that can show is there any bottleneck in controller interface? Not showing how many packets in and out, but to show whether the interface is being fully utilize.
    Thanks in advance
    Crone
  • 2.  RE: How to know controller is having bottleneck
    Posted Sep 22, 2016 10:04 PM
    When you say "fully utilized" what do you mean?  How many interfaces are there?
  • 3.  RE: How to know controller is having bottleneck
    Posted Sep 22, 2016 10:11 PM
    Hi cjoseph,
    Uplink only 1 interface, with 1Gb speed. Is it all time the 1Gb interface is fully utilize or not. Is it use 1Gb or less, or more.
    Crone
  • 4.  RE: How to know controller is having bottleneck
    Posted Sep 22, 2016 10:19 PM
    I would type "show interface <interface name>".  That will tell if there are any drops or errors or overruns that you need to be aware of...
  • 5.  RE: How to know controller is having bottleneck
    Posted Sep 22, 2016 10:30 PM
    Hi cjoseph,
    Ok noted on this. So this is the only command we can use?
    Crone
  • 6.  RE: How to know controller is having bottleneck
    Posted Sep 23, 2016 04:23 AM
    try show interface gigabitethernet x/x/x
  • 7.  RE: How to know controller is having bottleneck
    Posted Sep 23, 2016 04:28 AM
    What kind of bottleneck are you concerned about? I was thinking network.
  • 8.  RE: How to know controller is having bottleneck
    Posted Sep 23, 2016 05:06 AM
    You can also poll it with SNMP, this is a screenshot from Airwave:
    Gives you an idea on the utilization of the interface over time.
    Cheers,
  • 9.  RE: How to know controller is having bottleneck
    Posted Oct 06, 2016 10:15 PM
    Hi Christoffer,
    Ya, but customer does not have Airwave in their environment.
  • 10.  RE: How to know controller is having bottleneck
    Posted Oct 07, 2016 01:24 AM
    If they can't the budget for Airwave there are tons of free snmp based applications. Try googling it.
    Cheers,
  • 11.  RE: How to know controller is having bottleneck
    Posted Oct 07, 2016 06:49 AM
    @crone24 wrote:
    Hi Christoffer,
    Crone, the main "bottleneck" is traffic from access points.  The unwritten rule is that you have a single gigabit ethernet connection for every 100 access points.
    You can type "show log system all" to see if the CPU or Datapath exceed any thresholds, as well.
    If you do not have one of the two problems above, you probably do not have a bottleneck.
  • 12.  RE: How to know controller is having bottleneck
    Posted Oct 06, 2016 10:14 PM
    Hi Colin,
    Yes, network bottleneck.
