How to know feature active firewall session is enough for organization
This thread has been viewed 23 times
  • 1.  How to know feature active firewall session is enough for organization
    Posted May 12, 2022 10:54 AM
    Hi
    in datasheet Aruba controller series 7000 have a feature active firewall session 64k , I want to know how many concurrent active session. what command or menu web interface to show this active firewall session concurrent in real time.
    Best Regards
    Nattaphoom
    Nattaphoom Kangsri
  • 2.  RE: How to know feature active firewall session is enough for organization
    Posted May 19, 2022 11:40 AM
    Easiest is the show datapath session counters command:
    (md7010) #show datapath session counters
    |SUM/|       |                                   |                 |
    |CPU |  Addr | Description                                   Value |
    | G  | [000] | Current Entries                                1800 |
    | G  | [001] | High Water Mark                                5076 |
    | G  | [002] | Maximum Entries                               65536 |
    | G  | [003] | First packet classified entries             7959502 |
    | G  | [004] | First packet classification mismatc         1481180 |
    | G  | [005] | Total Entries                             108259402 |
    | G  | [007] | Duplicate Entries                                 4 |
    | G  | [009] | Current Max link length                           3 |
    | G  | [010] | Max link length                                   6 |
    | G  | [011] | Collision list with link len 0                  906 |
    | G  | [012] | Collision list with link len 1                  102 |
    | G  | [013] | Collision list with link len 2                  102 |
    | G  | [014] | Collision list with link len 3                    1 |
    | G  | [032] | Entries used in link len calc                  1111 |
    | G  | [033] | Stale Entries                                   266 |
    | G  | [034] | Aged Entries                              104366806 |
    | G  | [041] | Pending Delete Entries                          479 |
    | G  | [048] | DPI Info Tbl Idx Mismatch                         2 |
    | G  | [049] | DPI Info Tbl Idx Overwritten                      2 |
    | G  | [052] | DPI Info Tbl Idx Freed for rev                    2 |
    | G  | [058] | DPI Tbl Idx Alloc                          56831859 |
    | G  | [059] | DPI Tbl Idx Free                           56830947 |
    First three lines are relevant, in this example you see 1800 active sessions, where the peak value was 5076 and the max is 64k (65536). If peak/high water mark is below the maximum, you are good.
  • 3.  RE: How to know feature active firewall session is enough for organization
    Posted May 20, 2022 02:12 AM
    Hi Herman Robers
    Thank you for your answer, I have a one question. this session show on your capture command is only active firewall feature right? or this is overall session in firewall
    do you have a document output parameter of 'show datapath session counters' like this capture in below
    Nattaphoom Kangsri
  • 4.  RE: How to know feature active firewall session is enough for organization
    Posted May 20, 2022 10:08 AM
    I'm not sure if I ever seen such an overview. However for the current/high/max sessions you can replace tunnels by firewall sessions to get a proper description of the value. Typically I don't use these other numbers, they may be relevant for troubleshooting and Aruba Support knows how to interpret them.
