How to login to cppm using winscp and required default credentials
  • 1.  How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 07:03 AM
    Dear All,
    How to login to cppm using winscp and required default credentials.
    regards.
  • 2.  RE: How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 07:08 AM
    What are you trying to do?
  • 3.  RE: How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 07:14 AM
    You cannot SCP to ClearPass.
    Sent from Nine<>
  • 4.  RE: How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 07:11 AM
    want to load custom image to galaria skin path for CPPM guest.
  • 5.  RE: How to login to cppm using winscp and required default credentials
    Under Guest, use the Content manager.
    Sent from Nine<>
  • 6.  RE: How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 08:05 AM
    Hi, uploaded the custom image but there is no luck even after added the path.
  • 7.  RE: How to login to cppm using winscp and required default credentials
    Posted Apr 06, 2016 08:13 AM
    This is all I did to have my 3 jpegs rotate on the front page.  I put the following in the BackGround Image Settings of the Galleria Plugin after I uploaded them to the public root of the content manager:
    {literal}
    <script src="external/galleria/js/jquery.backstretch.min.js"></script>
    <script>
    $.backstretch([
    "public/myjpeg1.jpg",
    "public/myjpeg2.jpg",
    "public/myjpeg3.jpg",
    ], {duration: 3000, fade: 750});
    </script>
    {/literal}
