Wired Intelligent Edge
How to make "screen length" or "no page" permanent?
This thread has been viewed 30 times
  • 1.  How to make "screen length" or "no page" permanent?
    Posted Sep 13, 2019 12:49 PM
    I am trying to get rid of the need to constantly hit space bar on show commands. I have tried both the screen length and no page commands and neither one seems to be permanent. Once I reboot the switch and/or change sessions the commands stop working. Is there any way to make these options permanent?
    #2930M
    #2930M
  • 2.  RE: How to make "screen length" or "no page" permanent?
    MVP GURU
    Posted Sep 15, 2019 04:59 AM
    What switch OS ?
  • 3.  RE: How to make "screen length" or "no page" permanent?
    Posted Sep 16, 2019 10:13 AM
    Thanks for the response. The switches we are using are 2930Ms and 2530s so it should be ArubaOS.
  • 4.  RE: How to make "screen length" or "no page" permanent?
    MVP GURU
    Posted Sep 17, 2019 09:33 AM
    Do you have try
    terminal length 1000
  • 5.  RE: How to make "screen length" or "no page" permanent?
    Posted Sep 17, 2019 02:26 PM
    Paging is enabled by default for a new CLI session.
    This is a per CLI session command.
    Refer AOS 8.5.0.0 CLI Reference Guide(Page: 813).
    Use the command "no paging".
    The command should be the same irrespective of the code version.
    You need to have enable access to issue this command.
    This should solve having to hit the space bar continuously.
  • 6.  RE: How to make "screen length" or "no page" permanent?
    MVP GURU
    Posted Sep 18, 2019 08:56 AM
    this command (and guide) are for Aruba Mobility Controller...
  • 7.  RE: How to make "screen length" or "no page" permanent?
    Posted Sep 18, 2019 09:49 AM
    Hi Alexis,
    Thanks for pointing that out.
    The switch equivalent for the 2930f series is
    "no page".
    More information can be seen in the cli,
    Switch>?
    Information on toggling the "page" should be available.
  • 8.  RE: How to make "screen length" or "no page" permanent?
    Posted Sep 18, 2019 05:17 PM
    Thanks for the response. I have tried the "no page" command, but it isn't permanent. I would rather not enter it every time I login to a switch, so I was wondering if there was a command that wasn't tied to your session.
  • 9.  RE: How to make "screen length" or "no page" permanent?
    Posted Sep 18, 2019 05:20 PM
    Thanks for the suggestion, but after trying it it seems that is also tied to your session. I had to enter it each time I logged into a switch. Seems like there isn't a permanent option for that.
  • 10.  RE: How to make "screen length" or "no page" permanent?
    Posted Dec 07, 2021 12:01 PM
    The Switch CLI format is designed to show a paged output. You have to enter "no page" in every new session. There is no permanent option.
    Ranganath Vinod Vijayaraghavan
