how to manage IAP from wifi network?
  • 1.  how to manage IAP from wifi network?
    Posted Jun 23, 2014 08:18 AM
    I'm using 3x IAP 105 and managing them from LAN. How can I manage them while being on Aruba wifi subnet?
    I can ping the virtual controller address, but no luck with entering the https://IP:4343 site to manage it. I've double checked my firewall and there's no problem with the rules.
    Thanks in advance!
  • 2.  RE: how to manage IAP from wifi network?
    Posted Jun 23, 2014 08:22 AM
    Are you able to resolve https://instant.arubanetworks.com?
  • 3.  RE: how to manage IAP from wifi network?
    Posted Jun 24, 2014 02:07 AM
    Yes I am. Why can i manage IAP with that, and not by entering IP address?
  • 4.  RE: how to manage IAP from wifi network?
    Posted Jun 24, 2014 10:14 PM
    Can you try to do a DNS resolution on instant.arubanetworks.com and see what is the IP address? I don;t think it is a problem to go manage the VC via the IP address.
  • 5.  RE: how to manage IAP from wifi network?
    Posted Jun 25, 2014 05:21 AM
    Clear cache of your browser or use another one happened with me before I got it working verywell on another laptop or simply flush your DNS and make sure that you are on the same layer 2 domain.
  • 6.  RE: how to manage IAP from wifi network?
    Posted Jun 25, 2014 05:46 AM
    l don't think layer 2 or layer 3 have any issue.
  • 7.  RE: how to manage IAP from wifi network?
