How to manually failover AP in High Availability: Fast Failover w/o preemption?
  • 1.  How to manually failover AP in High Availability: Fast Failover w/o preemption?
    Posted Feb 17, 2014 07:46 AM
    In dual role without preemption if an AP that has failed over to a standby should attempt to connect back to its original active switch once that switch is reachable again.
    In VRRP design I would use vrrp shutdown for assigned vid, so that all APs moves to the high priority controller again.
    How do I this in FF so that APs goes to their LMS from Backup LMS if "Allow Preemption" is disabled?
  • 2.  RE: How to manually failover AP in High Availability: Fast Failover w/o preemption?
    Posted Feb 18, 2014 08:46 AM
    Does nobody knows how mannually trigger an ap failover??
    In RNs under AP Communication with Controllers described :
    An AP will failover to its backup controller if it fails to contact its active controller through regular heartbeats and keepalive messages, or if the user manually triggers a failover using the WebUI or CLI
    I can not find how I can do this manually
    Thanks in advance for your response!
  • 3.  RE: How to manually failover AP in High Availability: Fast Failover w/o preemption?
    Posted Mar 05, 2014 01:00 PM
    You can use the following CLI command to manually trigger a move of one or more APs from their current active controller to their current standby controller.
    'ap-move all' - Moves all APs currently active on that controller to their standby
    'ap-move ap-group <group-name>' - Moves all APs belonging to that AP group on that controller to their standby
    'ap-move ap-name <ap-name>' - Moves only that AP to its standby
    Hope that helps.
