How to monitor via SNMP if the Opeartion status chang to down
  • 1.  How to monitor via SNMP if the Opeartion status chang to down
    Posted Oct 19, 2016 03:49 AM
    HI,
    i need to monitor when an AP lose the ethernet connection and switch to MESH mode.
    There is some SNMP probe?
    In attachements you can find a screen of an IAP where the ehternet connection si down and it is working as MESH AP.
    Regards
    Andrea
  • 2.  RE: How to monitor via SNMP if the Opeartion status chang to down
    Posted Nov 01, 2016 12:19 PM
    Sorry for the late answer, but you might open a TAC case and they can look at the SNMP MIBs to find the best/proper SNMP message. Conversely if you capture the syslog from IAP, if you know the message you can write a trigger in AirWave to alert on that syslog message for when the eth0 goes down on the point.
