I have about 60 AP 204's (with dual external antennas) I need to hang in a warehouse. Is there any specific way I should or should not be hanging the AP's? I attached a pic of what I believe should be OK.
Since you are using external antennas, it doesn't matter how you mount the actual AP.
Will the AP204 "work" with no external antennas plugged in?
