How to obtain the APboot upgrade file of IAP-315?
This thread has been viewed 122 times
  • 1.  How to obtain the APboot upgrade file of IAP-315?
    Posted Mar 04, 2021 01:26 PM
    There is an IAP-315, before running os6.5, everything is normal.
    One day when I wanted to upgrade to os8.6, I found that there was no way to upgrade successfully.
    The CLI prompts that there is insufficient NAND space.
    Later I found out: The APboot version of this IAP-315 is: 1.5.5.4, and the other normal IAP-315 is: 1.5.5.5.
    Now I can determine that the problem is caused by the version of APboot.
    My question now is: Where should I get this boot file?
    Thank you!
    cy chen
  • 2.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Mar 05, 2021 04:07 AM
    Reach out to Aruba TAC support. The apboot should not be upgraded in the field, if you have this issue TAC may initiate an RMA if you are eligible.
    Please make sure you actually have an IAP (sticker on the back) and it is not an AP type that is not supported to run Instant firmware.
  • 3.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Jun 22, 2022 07:43 PM
    We are seeing this issue with AP-315 CAPs (NOT IAP model), with AOS 8.10.0.1.  It appears the AP-315 firmware image is now too big, just as with the Instant image.
    This is doing a TFTP upgrade directly from APboot (these APs have APboot 1.5.5.4):
    apboot> upgrade os 1 10.250.99.4:/ipq806x.ari
    eth0: link up, speed 1 Gb/s, full duplex
    Using eth0 device
    TFTP from server 10.250.99.4; our IP address is 10.40.8.56; sending through gateway 10.40.11.254
    Filename '/ipq806x.ari'.
    Load address: 0x44000000
    Loading: T T T T T T T #################################################################
    done
    Bytes transferred = 14799024 (e1d0b0 hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Image is too big; (14799024 > 14680064)
  • 4.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Jun 23, 2022 07:23 AM
    If you haven't already, please contact technical support.  They will evaluate what is wrong and suggest a solution.  There is not an apboot file just floating around out there that can just fix the issue.
  • 5.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Jun 23, 2022 09:34 PM
    Imagine my shock; TAC (ERT) just sent us the updated apboot image to load onto the APs.  I'm stunned.
    We're gonna work with the client to get it loaded on some APs tomorrow!
  • 6.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Jul 28, 2022 03:50 PM
    Just to follow-up; loading the updated apboot image onto the APs rectified the issue.
  • 7.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Mar 11, 2024 02:09 PM
    Hi I am in the same boat.
    ill have to contact tac for update boot image as well.
    did you have to do all these via local tftp? or is their a remote command similar to apflash backup partition
  • 8.  RE: How to obtain the APboot upgrade file of IAP-315?
    Posted Mar 11, 2024 05:43 PM
    Relevant support advisory announcement: https://networkingsupport.hpe.com/notifications/Tm90aWZpY2F0aW9uOjEzMDM3;notificationCategory=Product
    Carson Hulcher, ACEX#110
