How to output the crash.tar ?
This thread has been viewed 32 times
  • 1.  How to output the crash.tar ?
    Posted Aug 09, 2019 04:14 AM
    A controller 7010 shows a * on CLI. I used the command tar crash to clean the *,and it appeared a file named crash.tar by dir.Now i want to watch the error log , how to output the file crash.tar ?
  • 2.  RE: How to output the crash.tar ?
    Posted Aug 09, 2019 04:35 AM
    This command should help you
    tar clean {crash|flash|logs}| crash [kernel] | flash | logs [tech-support {no-controllerip
    | user <mac-address>}]
