Comware
  • 1.  How to PC to PC network w/ crossover cable?
    Posted Jan 02, 2003 04:14 AM
    I want to network my home computer (Win XP Pro) with my laptop (Win 98) using a crossover cable. Can someone give me step by step directions on how to do this?
    I tried allready, and sometimes the two computers can "see" each other and other time they can't. I have both computers on and the cross over cable is plugged in to each. I ran the Win XP networking Wizard on the home computer and it made a disk to install the networking parameters on the laptop. At times I am able to access the laptop from the home computer and othe I recieve an error that the laptop in not accessable.
    Any ideas?
    Jason
    #crossovercable
  • 2.  RE: How to PC to PC network w/ crossover cable?
    Posted Jan 02, 2003 10:14 AM
    the connection is this
    1 ---> 3
    2 ---> 6
    3 ---> 1
    4 ---> 7
    5 ---> 8
    6 ---> 2
    7 ---> 4
    8 ---> 5
  • 3.  RE: How to PC to PC network w/ crossover cable?
    Posted Jan 02, 2003 11:34 AM
  • 4.  RE: How to PC to PC network w/ crossover cable?
    Posted Jan 02, 2003 02:08 PM
    Ok, I bought a cross over cable to making the cable is not the issue. I need step by step intructions on how to "intall" the cross over cable so that both computers can see each other and share an internet connection. I tried using the Win XP networking wizard with limited success. Sometimes the computers see each other and other times they don't. Any suggestions on why this is or what to do about it?
    Jason
  • 5.  RE: How to PC to PC network w/ crossover cable?
    Posted Jan 03, 2003 03:43 PM
    Sounds like you need to add network protocals.
    check this site out.
    http://www.wown.com/j_helmig/mspc2pct.htm
  • 6.  RE: How to PC to PC network w/ crossover cable?
    Posted Jan 07, 2003 06:35 PM
    Sometimes in a windows peer-to-peer network, everything can be setup right, but it takes more than 1 try to get the workgrooup going. If you have both of them turned on and can not access the other try rebooting one at a time. I would probably reboot the Win98 computer first.
    Good Luck.
    Steve
  • 7.  RE: How to PC to PC network w/ crossover cable?
    Posted Mar 24, 2003 05:57 AM
    Ok, If I have understood...
    1 plug the cable.
    2 Have you put IP addresses on the two computers?
    If it's not the case, go in the network properties --> TCP/IP and put IP adress for example 192.168.1.2 (netmask 255.255.255.0) for the first and 192.168.1.3 netmask 255.255.255.0 for the second.
    When it's done, launch a DOS command prompt and type "ping 192.168.1.2" on the PC with the IP address 192.168.1.3.
    Do the same thing on the other PC (change the IP address in the command)
    If you have replies, there is the hardware connectivity.
    If it is not the case, there is maybe a problem with the cable or with the LAN card.
    Be sure that the Two PC are in the same "Workgroup", Go in the system properties --> Computer name.
    Now you should be able to see the other PC in the network neighborhood.
    You can also try to find the PC by looking for the IP address .
    Regards
    GD
