Hi all,
Having this ACL problem on a 2930F.
I want to permit
- SSH access from 192.168.100.130 to 192.168.100.83
- UDP access from 192.168.100.83 to 192.168.100.87
Block all the rest.
192.168.100.83 and 192.168.100.87 are IP addresses are on the same VLAN on the 2930F switch.
I am sitting on 192.168.100.130 which is another VLAN routed by a Firewall via intervlan routing.
I have this
ip access-list extended "Permit SSH and UDP, Deny all"
10 permit tcp 192.168.100.130 0.0.0.0 192.168.100.83 0.0.0.0 eq 22 log
20 permit udp 192.168.100.83 0.0.0.0 192.168.100.87 0.0.0.0 eq 514 log
30 deny ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
The above permits udp packets from 192.168.100.83 to 192.168.100.87 (I can see it in the syslog) but I am not able to access 192.168.100.83 from 192.168.100.130
Any ideas?
#Aruba#Switch_Router_Interconnect
